Cameras Logo
Question about Cameras
My VAX wont charge at all, no red blinking to indicate charge is working? Suggestions?
My vax stick vacuum wont charge
The problem may lie in your vacuum cleaner's adapter, charging dock, or battery and the electrical outlet. Try plugging your vacuum cleaner in to another outlet. If it is now working, the problem was in the first outlet that you have used. You should contact a certified electrician if you need to fix that outlet.
1helpful
2answers
Hi. My vax blade won't charge. The battery icon keeps flashing red and White any ideas?
flashing red just says turn it off because the battery is getting low. i guess thats cos it wont charge. wait 1 hour for temperature to become normal. wash filters and wait 24hrs til they are dry.check and clean battery contacts. those are the things the manuals list to try.
Roller brush not working on vax air mach 6
Hi I have a vax mach air light.the brushes wont turn but the green light is on. I have checked eveything .The little button on side tube no blocks .Checked all filters.
1helpful
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
4answers
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
1helpful
Same Problem
Hello, it was:
■ Charging LEDCharging LED
Green LED is on = Charging is complete
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
3answers
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
6helpful
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
