My Kyocera copier blinks 0000 then A-4, repeatedly. I have tried everything I could. cleaning dust, resetting, switching power off - on.
I hope someone has an answer.
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit. Clean/ empty the waster toner and vac.Also clean the sensor. You may have to change the Process unit if cleaning does not work.
