Trying to spray my atv frame Matt black , what do I need & which type of primer do I use ?
To spray paint your ATV frame matte black, you will need the following materials:
Before you begin, it's important to properly prepare the surface of the frame by cleaning it thoroughly and removing any rust or old paint. Use sandpaper or a wire brush to remove any loose paint or rust. Once the frame is clean and dry, apply a coat of primer specifically designed for metal surfaces. This will help the paint adhere better and ensure a smooth finish.
Allow the primer to dry completely before applying the first coat of matte black spray paint. Hold the spray gun or can about 8-10 inches away from the surface and apply the paint in thin, even coats. Allow each coat to dry completely before applying the next. Once the final coat is dry, you can remove the masking tape and newspaper or plastic sheeting and reassemble the ATV.
You need to buy a
special paint for metal with special additives that prevent rust. Make sure to also buy a primer that is compatible
with the paint you have selected. I
found you some great instructions that should help you out.
• Wipe
the wrought-iron bed frames with a rag that was dipped in mineral spirits. That
will help you to remove all traces of oil and grease from the frames.
• Scrape rusty
areas with a putty knife or scraping tool. Remove all loose rust scale. Rub the
surface with steel wool, too.
• Apply an oil-based primer. The primer needs to be designed for
use on metal surfaces such as wrought iron. Roll on the primer with a small
roller. Spread the primer with a paintbrush. Cover the whole surface with one
coat of primer.
• Paint the
bed frames with a finish paint that has a rust inhibitor within 24 hours of
priming them. That will help the primer and paint bond.
• Roll on the
paint in the same way you applied the primer. Use a paintbrush to make smooth,
sweeping strokes to distribute the paint. Switch to a paintbrush with synthetic
bristles if you decide to use a water-based paint.
Read more: How to Paint Wrought Iron Bed
Frames ' eHow.com http://www.ehow.com/how_7794293_paint-wrought-iron-bed-frames.html#ixzz232Q8GYhr
In this article you will learn the best way to spray paint anything from wood frames auto parts.
Difficulty:
Moderate
Instructions
things you'll need:
Start by removing the part that needs to be painted. (You can also tape around it, but be careful about overs pray)
Sand the part with the 300 grit sand paper until the surface is a little rough. This is necessary for the primer to bond with the surface. After sanding wipe down the part with micro fiber cloth.
Lightly spray the part with primer. A few light coats are better than one heavy coat. Make sure to allow proper drying time between coats.
After a few light coats of primer have been applied, wetsand with the 800 grit sandpaper. After wet sanding, wipe again with micro fiber cloth.
Now it is time to apply the color. When spraying the spray paint make sure to use smooth even passes across what is being painted. Do not start painting on top of the part because the paint will be heavier in that area. When painting you want to press and release the button to the side of the product being painted. Again a few light coats are better than one heavy one and make sure to allow proper drying time between coats.
After you are satisfied with the color, wetsand with 800 grit sandpaper and then wipe with micro fiber cloth.
Now it is time for the clear coat. Spray the clear coat the same way as the spray paint. Only one or two light coats are needed. Allow the clear coat plenty of time to dry as this is the layer that you will see most. You don't want any fingerprints on your final surface!
After the clear coat has had more than enough time to dry, You now want to wetsand with the 800 grit, then the 1000 grit, then 1200, then 1500, and finally the 2000 grit sandpaper. This should remove any heavier spots in the clear coat and will polish your painted product up very nicely.
Next you need to remove the scratches left by the 2000 grit. For this you will need to buff the surface with rubbing compound.
Now you need to buff the surface with a medium cut polish to give the surface a nice glassy look.
Whether it be exterior or interior parts that have been painted, I always add a couple coats of wax to the surface. This acts as a protectant to the clearcoat and gives it a nice smooth feel and also helps repel dirt.
