Televison & Video Logo
Question about Samsung Televison & Video
Replacing main board on Samsung 43" model UN43NU6950FXZA
To start several months ago my TV would not power up I do have back lighting and can hear sound and nothing on the screen went to shopJimmy and sent photos of TV without cover on back this model has only a main board and as out of stock I waited and just got a replacement from them followed the removal and replacement of main board Tried power up and flickered Attached a Roku and could hear the start up sounds on TV(added to HDMI)
Posted by Paul G McGregor on
I have a Samsung TV that has no picture just a black screen but can hear the audio. Is this repairable? It is Samsung Model #UN55ES6100F
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I have a faulty Samsung LCD TV and i would like help identifying the part of the TV that needs to be replaced.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I have a Samsung 40" LED TV UN40F5000AF...the lower half of the screen is dimmer than the upper half. It started about six months ago. Any ideas?
1helpful
Bottom half picture led tv darker than top it did this a couple of months ago then stopped
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
What caused video failure?
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
While watching TV, suddenly picture goes blank and sound is on
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
42'' Samsung Plasma Tv Screen went black but the sound works.
Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
2answers
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
Marvin
Marvin
