Washing Machines Logo
Question about AEG Washing Machines
My Aeg 7000 doesn't start, after switching ON when press the start /pause, it switches to 0 immediately. Help please.
Posted by Freddy Machicado on
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
4helpful
2answers
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
My AEG Lavamat 52810 has become faulty. The machine pauses about ten times during the cycle and the lamp marked "door" blinks. When I press the start button, it stops blinking and the cycle...
Hi Richard from retired Englishman in SW France,
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and
/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
AEG L76650 Front load washer. Approx 2 years old - set programme -ok, Press start button it appears to switch on, there is some start up sound but it doesn't move to fill with water. No problems on...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
3helpful
I need the code to unlock my DV550 LG dvd player
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
11helpful
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
works for other LG DV55X players
23helpful
3answers
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
I cannot play region 2 with it
please try this to make it region free
Multi-Region:
• Turn On the unit with the remote controller
• Wait until "no disc" appears in the unit's display
• Press Pause, 3, 1, 4, 1, 5, 9
• The word "CODE" should appear in the display
• Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
• Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
• Put the player into Standby mode
• Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
• Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
• Press Audio and Return for auto-switching On
• Press Angle and Return for MacroVision On
• Press Subtitle and Return for MacroVision Off
please rate me well or ask for more help before rating the solution
2helpful
2answers
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Top AEG Washing Machines Experts
john h
W.L.
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
