Washing Machines Logo
Question about Electrolux Washing Machines
I have an Electrolux washing machine in which it writes E anytime I switch it on and doesn't work at all
E 10
Posted by Farid sergio on
Simon Atkinson
  • Electrolux Master
  • 3,178 Answers
When you turn it on it should give you the 'E' and then a number. This number will show what the problem is likely to be. Comment below with the code and I'll try to help you more.
Posted on Sep 19, 2022
What's the meaning of error code E3 on my Electrolux model EWT604? The washing machine just beeps 3 times and showing an E3 error code on the LCD. Please, I need help. Thanks.
Abnormal condition of spin-dry
• The safety switch works 3 times continuously.
The number window LED display abnormal code: "E3" and begin blinking on and off at the same time and the electric buzzer sounds to indicate a problem.
Dado
Error code E3 on electrolux washing machine ewt604s
Dado
1helpful
Hoi, we have a washing machine Electrolux EW880F. Want not start anymore. Starting-light blinks and door-lock works not. Can you help me ? Thanks
Door lock assembly has to be replaced. If the switch there is not closed, no power will go to machine. Will not operate.
U can buy at this site Search Over 2 1 Million Appliance Parts
My washing machine model no ewf 1421,is writing e60,why
Insufficient heating measured by the main board during washing cycle and also during drying cycle at washer-dryer.
Could be faulty: heting element, pressure switch, NTC sensor, printed circuit board (PCB),
wiring between PCB - heating element,
wiring between PCB - NTC sensor,
wiring of pressure switch.
Dado
2helpful
2answers
Fault code EF electrolux EWT806 what is the problem
So we just fixed our EWT806 after it suffering the dreaded EF fault... The problem... Too higher mains voltage coming into the house! Albiet within specification from the supplier, the Electrolux EWT806 doesn't like anything around 250 volts! Obviously a poor design on the control board which is unable to accept a wide supply voltage!
Solution, isolation transformer inline with the machine. Now it runs like a dream!
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Open Questions:
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
