Air Purifiers Logo
Question about Sharper Image Air Purifiers
Sharper Image SI724 Hybrid GP Germicidal Air Cleaner will not turn back on after cleaning
This unit has worked well for years. I regularly clean the plates with my garden hose and the use my air compressor to clean everything else. I make sure all the wires are straight and the plates are not touching. After letting it dry thoroughly for a day or so, I plug it in and it usually works perfectly. However this time it does not turn on. I get nothing - No lights, no sounds, no activity whatsoever. It's like it isn't plugged in. Is there a reset button or magic button combination that I need to get it to start?
1 thinks its wet , 1 sparks and snaps.
I took the blades and a washrag in the shower with me and cleaned them. Then I put them in front of the air vent for 8-10 hours. Then I put them back in the unit. Sparking and snapping could be from dirt moving through the unit.
1helpful
2answers
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
1helpful
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
1helpful
2answers
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
1helpful
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
1helpful
Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
1helpful
I cleaned my air cleaner and now it will not turn back on
When you cleaned your cleaner, you must be gentle with it. Wipe down with a lightly moist cloth or paper towel. make sure you dont shove any grime between the metal cleaning grid and the plastic holding it all together. that can cause lots of problems. Your air purifier probably wont start because of an auto shut off safety feature. Be sure that everything is in its proper place.... make sure hte front grill is fastened on correctly as well as the back grill. if those are not secured properly the unit will not start. also, check that your collection grid is placed all the way inside the unit and wait for the click noise that indicates that its locked in place. at that point the unit should turn on and you can once again enjoy fresh, pure air!
2helpful
Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
5helpful
4answers
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
