Washing Machines Logo
Question about Hoover Washing Machines
START button on my hoover washing machine DYN8144D is not working.. any help would be appreciated..thank you..
Posted by Andrew Williams on
David Spradling
    Top Expert:
  • Hoover Master
  • 13,374 Answers
If voltage to display board bad board
Posted on Sep 19, 2022
My hoover dynamic 8+ washing machine Model number DYN8144D-80D displays an E08 error Code
E08 is the motor speed sensor error code. Suggestion: Try a cycle with very few garments and see if it completes the cycle.
1helpful
I was using a friend's washing machine (Hoover HNL 7126) and when I pressed the start button the whole control panel fell inside the cavity behind the buttons. How do I get it back out?
How to Replace Hoover Washing Machine Control Board
The above video might be helpful. If you are not technically inclined. A Service Technician might be a good idea. Pushing the start button should not cause this event in a properly working machine.
16helpful
3answers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
1helpful
2answers
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
2answers
Top Hoover Washing Machines Experts
W.L.
Steve F
Mike
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
