Miscellaneous Logo
Question about Miscellaneous
What cause the right rear wheel to make a clucking noise on a 2010 Hyundai Santa Fe when i step on the break making a stop?
I replace the wheel bearing hub assembly August the 10, 2022 and i just starting hearing the noise September the 16, 2022.
Posted by Joe Russell on
john h
    Top Expert:
  • Miscellaneous Master
  • 28,087 Answers
Debris --brake component bent or broken --dust shield bent tahe wheel off and inspect
Posted on Sep 18, 2022
  • Joe Russell Sep 18, 2022
    one of the brake caliper bolt lost off. how can i stop it from happen again?
The horn on my 2010 Santa Fe stopped working. Any suggestions or help
when pushing on the horn pad you may hear a click noise this tells you the circuit is good from the horn pad to the horn relay and out to the horn. find the horn and check for power at the horn terminal when the horn pad is pushed. if it lights up then replace the horn. if it doesn`t then you will have to check for a wire problem from the horn back to the relay. but horns are usually the problem.
2answers
Before i even touch the breaks it makes a noise and when trying to stop sometimes at the stop sighns again , can i still drive my car
Had the same problem on my 2005 Hyundai Santa Fe and I made a video on the symptom, what was causing it and how to fix it. Recommend you get it fixed as soon as you can.
My 2004 santa fe has 65k miles on it. Should it need ALL new breaks and the timing chain replaced as a garage claims? Also, replacing the timing chain costs $2800 according to the garage, and the breaks...
I would shop around $2800 sounds way too high!!! $1700 for breaks $425 per wheel you can do way better than that!!! If you have rear drums they last at least 2X front disc,call around you should't pay more than $1000 for 4 wheel disc. You are due for timing belt, you have time to shop around for better price.
Good Luck!
5helpful
2answers
2003 Hyundai Santa Fe ABS light is on along with TCS light
you may have damaged the ABS sensor or wire to the sensor up front check the wire that runs from the inner finder well and make sure it connected to the ABS sensor on the spindle
1helpful
2002 hyundai santa fe rear brakes creaking / scraping
change the brakes , the wheel bearings too should be ok
Top Miscellaneous Experts
Steven Wander
Steven Wander
Lonnie Arks
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
