Question about Pure Cell Phones
Cant find a reset e scooter not (cell phone)
It sounds like there may be an issue with the brake system of your electric scooter. Here are some steps you can try to resolve the problem:
Posted on Jan 30, 2023
SOURCE: Mercedes ML 500 Noise in Front Wheel
brakes are dragging. get them checked
Posted on Jul 22, 2008
SOURCE: how to unlock a cell phone
Try this. Disconnect the battery from 30 to 45 minutes. That is long enough for the capasitors to discharge and it should loose it memory. If that does not work then it is locked by the sevice provider, not on you phone, and you must contact them?
Posted on Jan 05, 2009
SOURCE: cant connect with the modem after cell phone mishap
Reconfigure your computer's software that was changed to make the phone work.
On the router, rtfm.
I doubt a cell phone could change the router's settings.
Posted on Feb 19, 2009
SOURCE: MY PHONE IS LoCKED AND I CANT REMEMBER THE UNLOCK CODE
the only way to change that password is to send it into verizon.
Posted on Mar 03, 2010
SOURCE: NEED A REPAIRMAN FOR A 3 WHEEL BATTERY OPERATED SCOOTER IN FLORID
well it most likely the the 5k ohm potenteitometer is bad this is a common ptoblem with pride scooters if you have a screwdriver and can take it apart you can order the part online and it comes with the wire tail on it so it just plugs into the controller board the part costs about 68 dollars from pride depending on what model you have, email me and i could probably walk you through it
Posted on Jul 11, 2010
