Ovens Logo
Rosanne Ristau Posted on Sep 16, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turbo chef heats up but menu won't come on - Ovens
Phelix Oguta
Level 2:
Novelist:
  • Expert 85 Answers
  • Posted on Jul 02, 2023
Phelix Oguta
Expert
Level 2:
Novelist:
Answers
85
Questions
0
Helped
5573
Points
258
If your TurboChef oven is heating up but the menu or display is not coming on, it indicates a possible issue with the control panel or display module. Here are some troubleshooting steps you can try to address the problem:
  1. Power cycle the oven: Turn off the power to the oven by unplugging it or switching off the circuit breaker that supplies power to the unit. Leave it powered off for a few minutes, then plug it back in or turn the power back on. This can help reset the electronics and may resolve temporary glitches.
  2. Check the power supply: Ensure that the oven is receiving a stable power supply. Verify that the outlet is working correctly by plugging in another device. If the outlet is functioning properly, check the power cord and connections for any damage or loose connections.
  3. Inspect the control panel and display module: Check for any visible signs of damage, loose connections, or corrosion on the control panel and display module. If there are any issues, it may require professional servicing or replacement of the affected components.
  4. Perform a factory reset: Consult the user manual or contact TurboChef support to find out if there is a way to perform a factory reset on the oven. This can reset the settings and potentially resolve software-related issues.
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
My Subway Turbo Chef is saying wr fail. I self tested and it came up okay, can't find this error message in manual
I have had an F8 error in the past. The wire connecting the top element had broken off. The reason why temperature is not getting up is becaise the top element is not working.
Turbo chef oven heats up too high and not ready
Bad SSR relay. Thermostat is for safety so it tripped first time, however since it's mechanical thermostat( not so accurate ) it didn't tripped on time for next time when it overheat
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
1helpful
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
My turbo chef owen sense somtime 208vac and some time 240vac
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Hope that helps, and thank you.
OVER HEATING
Hello. If the SSR is closed, and the oven is off, then the SSR is bad. You can call turbo chef for a part supplier,if you are able to replace it yourself, at 1800 90turbo.
1helpful
2answers
My turbo chef oven
The wave guide cover is a simple fix the problem being that after it is replaced you should have a leak check performed I dont know if you have a source to rent a refractomemter to perform this test. Most honest service companies will have a ref meter to check for rad leakage.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
