Blenders Logo
Question about Blenders
Ninja Blender BL610 won't lock on?
My blender came almost completely disassembled right out of the box. The bottom motor gear screw, it's gray, came apart from the actual motor base, and when I tried to screw it on, it would screw on one rotation, but won't completely screw on due to the fact that it just starts spinning. Because of this the pitcher will not fit all the way on and cannot lock into place. I've tried changing the washers to different places, removing things, but all in all I think it just doesn't screw on ALL THE WAY. Any idea on how to remedy this?
1helpful
How to remove the base gear from the Magic Bullet blender?
The screws are hidden underneath the feet, and they just pull out. This video shows complete disassembly.
https://www.youtube.com/watch?v=wJ0by1BYRt4
Mar 13, 2022 • Blenders
2answers
Why won't my ninja blender turn on? The red light is blinking, but power is connected and lid is secure.
try rotating the container part 1/4 of a turn to line up slots and press down . then if it does not blend turn another 1/4 turn to line up slots and press down pushing container into base motor unit .
container and screw on blade lid is put in upside down and the plastic posts have to match the base unit to turn on the blender when you press down on container into base unit.
I own and use a ninja blender !.
May 08, 2018 • Blenders
2answers
Why does my ninja blender power light blink red
-Make sure the lip is closed at the correct position and press down to lock before it let you turn it on.
Good luck
Mai
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Mai
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 • Blenders
5helpful
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
2helpful
2answers
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
4helpful
3answers
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
2helpful
2answers
Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Top Blenders Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Blender Expert? Answer questions, earn points and help others
