Tablets & eReaders Logo
Question about Tablets & eReaders
Hard reset for my tablet allwinner A100
If i put power button and volume down just thzat green androit robot comes on the screen thats it. What can i do Know
Tesfay
    Passionate:
    Visited the website for 10 consecutive days.
    Novelist:
  • 139 Answers
How to hard reset an allwinner A100 tablet If you're having problems with your Allwinner A100 tablet, you may need to perform a hard reset.
This will restore the tablet to its factory default settings and erase all your personal data. Here's how to hard reset an Allwinner A100 tablet:
1. Turn off the tablet.
2. Press and hold the volume up and power buttons simultaneously for about 10 seconds.
3. Release the buttons when you see the Android recovery screen. 4. Use the volume buttons to navigate to the "wipe data/factory reset" option and select it with the power button.
5. Confirm your selection and wait for the reset process to complete.
6. Once the reset is finished, select the "reboot system now" option.
Your tablet will now reboot and be as good as new!
Posted on Nov 24, 2022
Hanspree sn1at71b? Tablet (android)
A Hard Reset is the only way. Normally an Android reset is as follows;
Power OFF.
Press and Hold Volume Up and Power Button for 12 seconds.
However this says different
Press and hold the power button for 8 seconds to reset and reboot.
Hannspree Hannspad SN1AT71 Troubleshooting - iFixit
Videos as well
https://www.google.com/search?q=hannspree+sn1at71+hard+reset
1helpful
2answers
FACTORY RESET
Does this tablet have a volume control button? If so this is the reset instructions
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen. Select wipe data / factory reset with the volume keys and tap the Power button to activate it. Select Yes - erase all user data with the volume buttons and tap Power.
How do Im hard reset a Allwinners a31s tablet?
Try this one...
1. Turn off your Tablet
2. Press Power Button and the Volume UpButton at the same time until the Tablet show the Start-up Logo. then if you see the logo release the button.
3. wait until you see that your tablet is in Android System Recovery Mode.
4. use VOLUME DOWN BUTTON to go to the WIPE DATA/FACTORY RESET OPTION then Press POWER BUTTON to select.
5. then use VOLUME DOWN to choose YES--delete all user data then press POWER BUTTON
Bypass a forgotten lock code
Make sure the tablet has been turned off first by holding down the power button until you get the power off dialog box and choose power off. Then hold down the volume button and while continuing to hold the volume button, hold down the power button until you get a message like 'booting into recovery mode' or a dialog box that allows you to go into recovery mode and do a factory reset. Some tablets may boot into a screen with the Android robot on it that you can touch the robot and get to the recovery mode screen. When you do a factory reset, all user information stored on the tablet will be cleared, including the passwords or lock codes.
Don't know pin on my nextbook 7 ....how can I reset it
Do a hard reset!
Turn the unit off. Press and hold both the power button and the volume button at the same time, until the little yellow-green android robot comes on the screen. You can then release the buttons. You will eventually get a menu (this took a while to come up). Use the Volume button to scroll down to "Reset to Factory Standards", and select by pressing the power button. You`ll get a message asking you if you`re sure you want to do this. Use Power button again to select "yes". It will set the unit back to what it was like when brand new.
2answers
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Won't get past start screen when turned on
Try rebooting. Hold the power button till the menu pops up and click restart.
If that doesn't work try Hard reset Turn the unit off. Press and hold both the power button and the volume button at the same time, until the little yellow-green android robot comes on the screen. You can then release the buttons. You will eventually get a menu (this took a while to come up). Use the Volume button to scroll down to "Reset to Factory Standards", and select by pressing the power button. You`ll get a message asking you if you`re sure you want to do this. Use Power button again to select "yes". It will set the unit back to what it was when brand new.
By doing this you be ready to lose your saved data and setting
4helpful
3answers
Top Tablets & eReaders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
