Its 2016 model number 49L420U ,it only shows solid red light when plugged in. Also there is no power button on the TV only input button. Remote works fine i changed the batteries and checked it with my cell phone the UV light blinks. I used my universal remote still stuck at solid red light.I checked the power board nothing is burnt i get 5v and 3.3v but no 16v . Please tell me what to do.
The 5 and 3.3 voltage is standby and that would be good if you get a standby light, you won't see the 16 volt unless the power supply is at full power or out of sleep mode. Look at the legend on the power board connector going to the main for something like PWR_ON, it may be marked different, but will have something about power on, you need to see just over 3 volts there when you push the power button, if 3 volts is there replace the power supply, if you don't see that go to the connector coming from the inferred board on the main board, measure the voltage at the pins, one will be 5 volts and one of the others need to change voltage when you push the power button on the remote, measure these one at a time, if none chance replace that board, if you see a change in voltage on one of the pins replace the main board.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
OK.
