Hi, my 2.0 2012 Volvo S40 cuts immediately after starting it. When I turn the key the first time, it will start then show promise of idling and die just before it idles. It will do this for a few attempts and then not start at all. The next day, if I try to push the accelerator while starting then it speeds up the process of it not starting at all. All of the fuses are fine. The battery voltage seems low - I've tried to jump it and the car still won't idle. I've tried a different battery in the car and the same things happen. Checked all of the plugs and the first plug had quite a lot of oil in it - cleaned it and replaced it and still nothing. Please help.
Probly need anew coil or ign module. Plugcables cud be worn tu. Fuel system cud b dirty. Compression cud be weak..try som starting fluid to see if it runs longer. But a haynes shop manual at parts. ...ithink ur alternator is bad or the connections are. Havit tested and run ascan for codes. May need amobile mechanic
Testimonial: "Thank you for your response. How would I know what it is? Run a diagnostic?"
To
troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
To
Car Repair Diagram
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
1995 Lexus LS400: Running Hot?
2002 Toyota Camry: Puff of Blue or White
Smoke while Starting?
Multiple problems on car: Car runs hot, A/C
blows hot and car starts surging?
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
Vehicle
Starts, Runs and Loses Power
Intermittent starting issues on Volvo 760?
Car starts and cuts off immediately?
Car won't start when cold?
These details will help.
Thanks.
