Washing Machines Logo
Question about Bosch Washing Machines
E47 error code Bosch washing machine
Does anyone know what is the error E47 about on a Bosch washing machine wan28120? I found 2 clues on internet about an issue with the thermostat and an issue with the motor controller. The machine is not starting the cycles, not spinning and beeping two time every couple of minutes. Thanks!
Posted by Adrian Serna on
NOEL
    Top Expert:
  • Bosch Master
  • 8,603 Answers
Hi Adrian.
this is all i can find,
Bosch Washing Machine E47 Error - Heat Sink on Motor PCB Fault
Description:
Heat sink on the motor control module is broken.
Action To Take:
  1. Replace motor control module.
  2. or go to this link it will give you all the codes.
  3. https://appliancefault.com.au/faults/washing-machine-faults/bosch-washing-machine-fault-codes/
Posted on Sep 12, 2022
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 • Dryers
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
3helpful
What does Code E:00 mean on a Bosch washing machine 7kg WAK2020SME?
It is strange, but this error code should not exist.
I found a youtube film, explaining most codes and what you can do to solve it. Take care, when you don't have the correct skills, ask a tech.
How to Identify an Error Code on Bosch Washing Machine
2answers
Our Frigidaire Affinity washer has error code E47
the error code E47 means your door latch/lock assembly is bad.
1helpful
BOSCH WAA24270GB error code 0 and 2 backwards rr
Press START button over 10 second, its working for me
No spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
