Computers & Internet Logo
Conlog key pad not pressing has sound with kwh only on d screen
Atharva Mahajan
    Problem Solver:
  • 6 Answers
If the Conlog keypad is not pressing the buttons properly, it may be due to a malfunctioning keypad or a loose connection. You can try the following steps to troubleshoot the issue:
  1. Check the connection: Make sure the keypad is properly connected to the meter. Check for any loose connections or damaged wires.
  2. Clean the keypad: If the buttons are not responding properly, it may be due to dirt or debris. Clean the keypad with a soft, dry cloth.
  3. Restart the meter: Turn off the meter, unplug it from the power source, and wait for a few minutes. Plug the meter back in and turn it on again.
  4. Contact the manufacturer: If the above steps do not work, it may be a hardware issue. Contact the manufacturer or a qualified technician for assistance.
Regarding the kwh reading on the screen, it could be that the meter is only displaying the kwh reading, and not the other information. If you want to view other readings, you may need to press a button or navigate through the menu options on the keypad. If the keypad is not working properly, this may be difficult.
Posted on Feb 25, 2023
How to input a token on conlog meter
https://geeky.com.ng/how-to-load-conlog-prepaid-meter-token/
CIG Meter Activation Guide ' Ikeja Electric
https://www.ikejaelectric.com > cig-meter-activation-gui...
Conlog Meter=04xxxxxxxxx. Put the meter number and press "enter" (meter will display succeed). Step 2: Confirm you have loaded your meter activation token ... People also ask How do I load my token on Conlog prepaid meter?
How do I load my electricity token on Conlog?
Why is my prepaid meter rejecting token?
How can I load my prepaid meter Online?
Feedback Web results
NHC Meter Activation Guide ' Ikeja Electric
https://www.ikejaelectric.com > nhc-meter-activation-gu...
Conlog Meter, Input 009 & press enter and the current unit on the meter will display. EDMI Meter: Single Phase: Input 10 & press enter and the current unit on the ...
How Do I Load The Activation Token On My Conlog Prepaid ...
https://www.nairaland.com > how-load-activation-token...
Mar. 17, 2020 - Goto http://kctmanagement.conlog.com , Enter your meter number to generate your activation codes which are usually two 20 digits. Enter the first 20 digits and ... I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
Please Help With My Conlog Prepaid Meter - Technology ...
Aug. 6, 2020
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
Prepaid Meter Codes' How To Recharge & Check Balance ...
Jul. 28, 2018
More results from www.nairaland.com
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
7helpful
2answers
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Completion
3helpful
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Marvin
Marvin
