Televison & Video Logo
Question about LG Televison & Video
Lg tv no sound
My lg 42lV355U-ZB tv sound keep,s going off can you please help me fix it,tried switching on/off,switched off at mains,help power button on tv for 30 seconds,tv for 60 seconds and still nothing
Posted by SONYA ROSS on
Larry
  • LG Master
  • 4,808 Answers
Replace the main board if you can find one at a decent price.
Posted on Sep 10, 2022
I have a LG 50PG60UD - AA television that appears to be overheating. TV starts up ok and keeps working without any major issues. A couple of times recently I have unintentionally switched it off and when...
This isn't an easy fix, it sounds like your power supply board is bad or there is a main board problem. I'd suspect a faulty power supply capacitor or heatsink missing, but you have to bring it in to a tech to know for sure.
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
5helpful
LG RE-44SZ21RD 44
This is vcaused by a relay similar to a fluro/ neon light starter switch. This part has failed so it cannot get syncronization You will neede to have a serviceman replace this part.
Please rate our help to keep the free service online
4helpful
2answers
Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
1helpful
2answers
LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
2answers
LG TV problem
Standby solutions
Marvin
Marvin
