Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE Logo
Question about Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE
Kenmore Elite Dishwasher. The red flap/door on the rinse aid will not stay closed. How do I repair it?
Kenmore elite dishwasher approx. 10 yrs old. The little red door where the rinse agent goes will not stay closed.
ADMIN Andrew
    Top Expert:
  • Kenmore Master
  • 57,483 Answers
There are many Kenmore Elite models with numerical identifiers. You may be able to replace the rinse aid door, or you may have to replace the whole door, if parts are available.
Google
kenmore elite (model) parts
Posted on Sep 08, 2022
I have a kenmore elite ultra clean dishwasher. Have only used it two times. Does not dry well. Lots of water left Read Manuel. Extra dry should not always have to be used. Water still on door after a...
RINSE AID! Buy a bottle of Jet Dry or similar rinse aid liquid. Fill the rinse aid dispenser completely. Run dishwasher as usual. Water will no longer cling to the tub or the dishes. Newer dishwashers require rinse aid to dry properly due to reduced energy consumption.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 07, 2014 • Dishwashers
My Kenmore Elite dishwasher gives a message "Rinse Aid Empty". What does this mean?
It means the rinse aid dispenser is empty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
3helpful
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Dec 20, 2008 • Dishwashers
Rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
542helpful
22answers
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
