Panasonic Plasma Lcd Tv Remote Control N2qayb000100 Th-42pe77u N2qayb000102 Logo
Question about Panasonic Plasma Lcd Tv Remote Control N2qayb000100 Th-42pe77u N2qayb000102
Panasonic plasma tv if you power on doesn't turn on.
Just sit there clicking trying to power on.
Posted by Charles Atherton on
Larry Ng
    Top Expert:
  • Panasonic Master
  • 9,927 Answers
Moved you out of cars to TV
no model TV told, at all off rear label.
there are 2 causes (dead picture and dead sound)
PSU dead
PSU overloaded
there are tested for all
check all DC rail voltage to spec.
then if one fails, we disconnect load to this DC pin and see if PSU wakes up. if does the load removed is bad
the service manual cover all this (schematics)
Posted on Sep 07, 2022
Continuous blinking light on Panasonic Plasma
had the same problem wih my panasonic, it was a faulty power switch. make sure the power switch is sitting centrally in its housing, if not you may need a new switch
The on/off switch doesn't work on our 37inch Panasonic plasma tv
There should be some fault with its main power supply regulator board. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
I have a 2008 46 inch Panasonic Plasma. Whenever I try to turn on the tv within an hour of turning it off, the tv doesn't turn back on and the power light blinks. To get the tv to turn on I h
I will be the barer of bad news. your Panel is failing. Plasma TVs are only made to last 5-7 years. 10-12 is more realistic from what I have seen. The TH46pz85u is a great model of TV but when that starts happening it means the panel is beginning to fail. Replacing the panel is cost prohibitive and they don't even make them anymore.
You will be wise to spend your money on a new TV. newer TV's are much more power efficient as well. your 46" TV draws a lot of electricity. Your TV draws almost 650Watts of power. A comparably sized TV today(55" or larger) Draws around 200 watts. Significantly less.
My Panasonic viera tv will turn on and off but no other buttons work On the remote or on the tv itself
Try unplugging power cord for 10 sec. or for over night. That might be the trick. I did the same trick on a satillite receiver and a DVD player that got stuck like your tv is doing and it worked, doesn't hurt anything to do so. Hope this helps.
1helpful
2answers
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
2helpful
2answers
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
