Optics Logo
Question about Optics
I need a manual for a GET DHMD DEHUMIDIFIER UNIT
SERIAL NUMBER 01134980 MODEL NUMBER DHMD10
How do u operate Danny dehumidifier model DDR607EE I don’t have a manual for it
I found a PDF of the owner's manual for the Danby DDR607EE at Reliable Parts, http://www.reliablepartsinc.com/danby/dehumidifiers/DDR%27S/DDR607EE/ . The direct link to the manual is http://www.reliablepartsinc.com/danby/dehumidifiers/DDR'S/DDR607EE/OWNERS%20MANUAL.pdf . However, before you use this dehumidifier, go to https://www.recallrtr.com/dehumidifier . Use the drop-down menus to select Danby and the model. Then enter the serial number and make sure that this unit doesn't have the manufacturing flaw that could cause a fire.
I hope this helps.
1helpful
Is there a recall on Frigidaire dehumidifier Model FAD504DUD
Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
Without the serial number, I can't be sure if your unit is in the 2016 recall. For details, you can look at https://www.cpsc.gov/Recalls/2017/Dehumidifiers-Made-by-Midea-Recalled .
I hope this helps.
I bought a cool works dehumidifier and have no manual for it.It is mdl-50aeni-ba9 serial no.:d205023130212c06200635. Could i have one sent to me please.
no
not from fixya site as we do not have any paper work for anything
get it from manufacturer web site on google
How to adjust the humidity level
Hello Friend, that's a great question!
In order to better assist you I would need your model number please. The serial tag, which lists your model number, is typically located behind the bucket on your dehumidifier. Also, what is the size of your room/basement? Where is the dehumidifier located? What setting is your dehumidifier set on? With this material I can provide you the correct information. Thank you! - Z
What sixe diameter tube do I use to hook up to empty dehumidifier
In order to better assist you I would need your model number please. The serial tag, which lists your model number, is typically located behind the bucket on your dehumidifier. With this information I can provide you the correct part number. Thank you! - Z
E3 code...what to do? on dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can provide you with the Error Code solution, as well as email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
3helpful
Bought a Maytag 65 pint dehumidifier second hand. A hose or tray didn't come with it. Need to buy parts and would like to get a free owners manual. Model # M7DH65B2A*A Thank you, J Duke
You can find the manual and the parts online a Sears Parts Direct. However, when you enter the model number, drop the *A off the number.
FYI - This unit was made for Maytag by Fedders. And they make one of their own, with the same model number.
Hope this helps you.
I need a manual for a GET DHMD10 dehumidifier, please.
http://www.getplc.com/site/content_25.aspx?q=dhmd10
I need the same manual - this is best i could find. Space to put in exact model but does not appear to be spot on match - i guess same principle applies for this model... mine had stoped collecting water although it makes all the right sounds... so got a new one now and am well pleased with it.
Top Optics Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you an Optic Expert? Answer questions, earn points and help others
