Refrigerators Logo
J
John Skidmore Posted on Sep 06, 2022
Hello, I have a Kenmore 10651763510. The refrigerator isn't keeping cold.
The evap fan is not circulating and it appears the evap isn't getting cold. It appears to be a thermostat/thermistor issue. I'm looking for the wiring schematic to further troubleshoot.
Kenmore refrig. Evaporator keep freezing up .
Is the inside evap fan circulating air? Is it even running? Check those things first before looking for the reason for lost freon.
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
2helpful
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
My ice cube maker isn't making cubes,but I still get water
hello,
In a case like that usually the problem is going to be a cooling issue, is the fresh food and freezer section both cold? it obviously takes water and freezing tempatures to make ice.
2 things to check are
1) the condenser coil under the grill below door or on back depending on model is clogged with dust and needs to be cleaned
2) the fan in the freezer isn't running circulating air into ff section and directly onto icemaker
Good luck, i hope this helps
Gene
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
Other Causes
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Have a good day! : )
Freezer not freezing freezer compartment and cooler compartment not cold. frozen goods are all thawed. lights still operate when door opened
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Hope this will solve the issue.
The freezer is not cold
I hope the above helps.......
Good luck.
Freezer staying cold but fridge side is HOT
The Evaporator fan is not working. Located in the freezer above the evap coils is the circulating fan. Remove the cover to access the evap coils and circulating fan. If fan runs you have a defrost problem and the evap coils will be frozen over.
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
My refrigerator is not getting cold,but the freezer on top is just fine,How much will this cost to have a repair guy come out?
you need to check if the evap. fan is good maybe not spinning to circulate cold air into the fresh food compartment(i.e.refridgerator
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
