GPS Logo
Question about Raymarine GPS
Charts won't load on raymarine e80 chart plotter
Hi, I've been having the problem that the charts on my raymarine e80 are not loading onto it. Apart from this the system seems to be working fine with radar and AIS working normally. The charts loaded up fine 4 weeks ago, but as I've been moving along the coast and changing the cards for different areas they have stopped recognising them. Any help would be very much appreciated.
Posted by Benjamin on
1helpful
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
1helpful
Raymarine a50d continuously resetting itself?
If there's a memory card installed for maps, try starting up the unit with it removed. It's possible that the card might be corrupted and stalling the start-up sequence.
6helpful
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
2helpful
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Charts not working
Your chart reader may be messed up on your E-series. Contact Raymarine and inform them of the problem.
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
1helpful
2answers
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Top Raymarine GPS Experts
Mike
ADMIN Andrew
ADMIN Andrew
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
