Photography Logo
Question about Photography
How do I rotate a photo on a Sharing PF1006 digital photo frame?
I have a Sharing PF1006 digital photo frame. Several of the photos are displaying horizontally rather than vertically. I can't find a way to rotate them. They are on the SD card correctly.
Posted by wgrimes1 on
ADMIN Andrew
    Top Expert:
  • Photography Master
  • 53,546 Answers
Edit them before you load them onto the SD card. All the images are shown in one orientation, but some are supposed to 'auto rotate'.
check out the link
https://www.google.com/search?q=rotate+a+photo+on+a+Sharing+PF1006+digital+photo+frame
Posted on Sep 03, 2022
Testimonial: "I did that and it didn't make any difference. They aren't auto rotating."
  • wgrimes1 Sep 04, 2022
    Thanks, Andrew. I did that and it didn't make any difference. They aren't auto rotating and I don't see a rotate option in the settings.
  • ADMIN Andrew
    ADMIN Andrew Sep 04, 2022
    Is it like this with a remote? Page 6 'Rotate' whilst in Pause Mode.
    https://www.digitalframesdirect.com/cont...
    The is nothing listed specifically for 'Sharing PF1006 manual' apart from the above.
I can rotate pictures on my Aluratek digital photo frame but cannot get the rotation to save. How can I do this on the photo frame?
after u rotate the photo if you select the next photo in line , it should delay for a moment and say :updating: this it saving your rotation in its memory , or why not just rotate in in camera or computer , then save it to frame alllready rotated !!
Oct 20, 2016 • Photography
Sylvania sdpf 1089
Rotate images correctly. : NIX Digital
https://support.nixplay.com/entries/66055804-Rotate-images-correctly-
Apr 7, 2015 - images that are uploaded to the frame should always display .... I amdisplaying images from my SD card. ... of photos coming from USB or SD will stillneed to be rotated if there is an exif ... "save as " from the account they are the correct orientation on my computer. .... Everything worked correctly after that.
Photo Rotation Problem - [email protected]
community.insigniaproducts.com/t5/...Photo.../Photo-Rotation.../td.../508...
Dec 28, 2009 - I have a few pictures that I already rotated correctly on my computer. Even so, they display incorrectly on the digital frame (buildings and people. ... When I bring the picture back to the picture frame, the rotation is still .... Just extra info - If I put the picture directly into Internal Memory .... Save as 24-bit Bitmap.
Galaxy S3: Photos are always being rotated! Why! - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S3
2helpful
How to save photo after rotated
If you use "Windows Picture and Fax Viewer" you can use the rotate buttons on the bottom of the program. And then simply hit either the left or right button and this will save it for you.
5helpful
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Some of my vertical (portrait) photos on my 15" are displaying as horizontal (Landscape). What can I do to fix this?
Have you saved the images that are appearing as Landscape in Portrait?
The frame should display the images as you saved them. Rotate the image in your photo editing program until they appear as Portrait, then save them. This should fix your problem.
2helpful
Frozen Screen on Digital Photo Frame
I have the same problem!!!
Did your frame already work?
3helpful
How do I keep a photo rotated?
Not all frames can save rotated images. Try rotating a photo on the frame's built-in memory, not one on a memory card. If it still does not save, then this model does not save rotated images.
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
1helpful
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
