Televison & Video Logo
Question about Hitachi Televison & Video
My HITACHI TV show 3Amok when i press any button, so there is any way can help yo fix it
1helpful
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
1helpful
My tv write 3AMOK on the screen , when you press Any button ,it write 3AMOK What is the problem HITACHI
It's an error code and means the set is in lock out. You may need help from Hitachi to get it running.
How do I fix the zoom on the tv?
Press the settings or menu button on your remote. There should be an option for aspect ratio. Set it to widescreen or 16:9
Been given a Hitachi tv and it doesn't seem to tune into any station. I have no manual and the hand set seems to be working.
Press the menu button. You will get a set of questions. You select he coorec one that suit you and tune your TV. Mostly the set up menu! select auoto tune and watch. It will search and save automaticaly. Later yo u change to your choice using the menu!
1helpful
2answers
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
TV all buttons are blocked and i don t have remote
A simple TV remote app, applications for your streaming device (such as Roku or Chromecast), and general streaming service apps are available (such as those for Netflix or Hulu). The app (s) that will be most beneficial to you will be determined by whether you primarily use your smart TV or a streaming device.
Hitachi TV HELP!
Hi, magic focus button is behind a small door on the front of the set just below the screen, I don`t think it is going to help I believe your convergence IC`s have failed,try pushing it once and let it finish, if still 3d image you need to call a tv tech, good luck, video-tek
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
1helpful
Imm stuck on the cbbc chanel on digital
Press the up channel button on your remote.
If this doesn't work then change the batteries or press the channel button on your TV
53uwx10ba hitachi
only one click?
any blinking lights?
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
