Olympia OL3000.2 worked perfect before. the only problem now is that when there is an incoming call, its like it doesnt even aknowledge that a call is coming in. it doesnt display any caller ID, it just goes about its standby business as the phone is ringing...
SOURCE: no more illumination
It's dead sorry to say.
We have owned several of them in the past and the manual itself is NO help.
We have tried to call Olympia and Sharper Image and still no help.
They have a very short life span, unfortunately.
The only thing that you might be able to do is, unplug the unit for about an hour or so, and plug everything back in. It may reset itself.
SOURCE: Olympia, and/or Sharper Image infoglobe. Need fix.
It appears that you have already removed the 4 screws. The globe will not just fall off, it has to be pried. Take a small- bladed screwdriver or a small-bladed pocket knife and gently pry from any small opening you see between the globe and its base. Work the blade around the globe and it will come off. I just did it and now I'm trying to figure out how to get inside the "guts" of the globe. Will keep you advised.
SOURCE: Olympia Globe Caller ID
I just printed a manual in pdf form go to,http//smarthome.com/manuals/5109.pdf
SOURCE: how to change time on Olympia Infoglobe caller id
I have the manual and can tell you what it says:
(this worked for me last year when we went off daylight savings, but for some reason, It doesnt seem to work anymore. I can't imagine that I did anything different then. You can try, though.)
Enter (or leave) the Demonstration Mode by pressing the right key for at least 1 second.
Then, by pressing SELECT key, you are SUPPOSED to be able to scan a menu which lets you pick date format, time format, etc.
This no longer works for me, and the instructions also have a contradictory comment that says the SELECT key is disabled in this mode. But perhaps this will work for you.
I would also appreciate instructions if anyone knows what I am doing wrong.
SOURCE: My Olympia cdp 24201 has no sound i called it from
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
