Car Audio & Video Logo
Question about Jensen Car Audio & Video
I have a Jensen JMS7010 marine radio it has water in the face I want to take it apart and dry it out and try to save the radio but it want come apart how can I dry it out or take it apart?
Posted by Donald Ward on
2answers
How do you change the fuse in my Jensen Pro Media 5000 system?
Not much on it and the manual doesn't mention a fuse. Contact Jenson direct, they are a great company. I have a marine unit.
https://www.google.com/search?q=Jensen+pro+media+5000,+replace+fuse
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Instructions to use ipod
hello if you have the interfase cable just connect it
use the stereo menu and your re done
ICOM IC-M125 Marine display is on solid with all functions displayed
Hello many marine radios have been outdoors over the winter and do get water inside even though they they are water resistant. It may have water damage inside and need to be cleaned with a brush and alcohol and dried out for several days
Clarion marine M455A
Go to the CLARION website and look for CUSTOMER SERVICE. You can either call or e-mail a description of your dilemma with the radio. The company stands behind their products. If it is still under warranty you may find it easier to first go to the store where it was purchased. They will give you a new unit if it is within the 30-day purchase date or at least offer to send it to Clarion for repair. Make sure you get a RETURN AUTHORIZATION number from the company. As far as being a "marine" radio, it is still an electrical product in a wet environment. The radio chassis is protected with a stainless plate to shield the circuitry. There is gasketing to prevent moisture from entering. Even the so-called waterproof handheld vhf radios claiming submersible protection have a limit to how long it can remain submerged before it loses watertight integrity. If saltwater invades to circuitry, immediately disconnect the power source (never try to turn it on if it IS wet.) and remove the unit so that you can RINSE as soon as possible the exposed electrical connections with FRESH WATER to remove the salt BEFORE it drys and becomes encrusted. Do Not allow the salt water to dry and become encrusted and the damage is done. Salt destroys electrical connections; eats 'em up! THEN blow-dry on a low setting and set it aside to complete the drying out process. Some wags suggest placing it in the oven on alow setting. I DON'T. Good Luck.
May 31, 2013 • Boating
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
1helpful
2answers
HOW DO I FIND REPLACEMENT FACE PLATE & REMOTE FOR JENSON MODEL #DV2007
Here is where to get a replacement waterproof remote - http://www.jensenmarinedirect.com/jensen-waterproof-wired-remote-control.html With these marine radios the faceplate is usually the first thing to fail from water damage. Not that your is water damaged but because of this finding a used one is impossible on the net. You will have to contact Jensen for to see if they have the faceplate available separately. http://audiovox.com/jensen/ Good luck.
Regards, Tony
Looking for a store in pei canada
TRY A MARINE SUPPLY STORE...THEY USUALLY CARRY JENSEN MARINE RADIOS AND CAN ORDER EVERYTHING ELSE....OTHERWISE BUY ONLINE.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Water entered my i-pod and now it isn't working.. it only shows the apple symbol when i charge it.
it happened to me too. Dry it up with a blow dryer before trying to power it up. but it probably was not a good idea to power it on before completely drying it.
Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ [email protected]
Top Jensen Car Audio & Video Experts
ZappaNut
ZappaNut
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
