Question about Yamaha Audio Players & Recorders
What does error code 0010 mean on Yamaha av receiver Rx-v773
Im trying to update the firmware on my Yamaha av receiver but at step 'S2-5: verifying' it fails and displays error 0010
Posted by Robbe Tempels on
ADMIN Eric
    Top Expert:
  • Yamaha Master
  • 37,638 Answers
- Firmware update doesn't start or doesn't complete
? Receiver doesn't power up after the update.
? Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
- Error message appeared during the update
Cause: For some reason, the receiver can't read the firmware data.
Method: For your solution, check the following
[Update through Internet]
? Check Internet connection.
Check if the Internet connection is working by playing an Internet radio station.
(See owner's manual for details)
[Update by USB thumb drive]
? USB thumb drive is connected properly to the receiver.
? USB thumb drive is not password protected.
(AV receiver cannot read data from a security protected USB thumb drive)
? Make sure the USB thumb drive is inserted before the receiver is powered on for the update.
? The firmware data is stored in the root directory of the USB thumb drive.
? There is no other data except the firmware data in the USB thumb drive.
? No folders are created in the USB thumb drive.
Else, retry the update by USB using another USB thumb drive.
Posted on Aug 31, 2022
Testimonial: "I tried the usb update 2 times, used a different USB stick for the second try. Both were fat32 formatted. Didn't try the network update cause it seemed sketchy to me. Will try it now."
  • ADMIN Eric
    ADMIN Eric Aug 31, 2022
    Ensure you are loading the correct file!
Yamaha av reciever RX-V773 decoder does not turn on.
Check you power cable if it's properly connected and if it does not work try getting another power cable and see if it will come up
I connected the HDMI 1 input from my tv to the HDMI output on the Yamaha Rx-v673 but i do not get any signal going throught to the tv. when i try put my samsung input source as HDMI 1 the tv prompts me...
To connect a TV you should use the Rx-V773, not the 673.
With the 673 you can use TV only as input, not output.
However there is a firmware update for your receiver. Try it.
6helpful
2answers
Rx v373 firmware update
Usb crashes after playing several music and stops loading contents from usb. I had to turn the power off and on again to load. Is there any latest firmware for Rx v 373 yet?
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
1helpful
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Need code for Yamaha RX-V367 for Motorola DRC800 remote. Thanks!
Thank you for your question.
Yamaha RX-V367
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v367_black__u/?mode=model
Motorola DRC800
Here are a few codes to try:
0054
0030
0179
0706
2helpful
I have a Yamaha Rx-v367. I have the Wii console connected as shown on page 17 in the pitiful excuse for a manual that comes with this receiver; composite video (blue, red,green) hooked up to AV1 and the...
Yamaha has posted specific support for nintendo Wii as well as a couple firmware updates. If you still need some help, post a comment ant I can help you further.
My yamaha recever when I turn it on goes all the way up.I mean the volum everytime.Im not sure but did someone set it that way?
Yes, yamaha receivers can be configured to a specified volume level on power-on.
For my receiver it is at Setup menu / Func. setup / Volume / IniVol.
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
