Air Purifiers Logo
Question about Oreck Air Purifiers
My Oreck XL AIR12GU air purifier suddenly won't turn on - No lights or noise. How do I get it working again?
My Oreck XL air purifier suddenly won't turn on (No lights or noise). It's a Type 1 AIR12GU. I've cleaned the Truman cell, the pre filter & all of the in/out openings. Everything seems to be fully re-seated. How do I get it working again?
Posted by Barb on
1helpful
I have a professional XL oreck and the light stays red at change odor absorber and it's been changed
https://www.manualsdir.com/manuals/204678/oreck-xl-rrofessional-air-purifier-airp-series.html?page=11
The blue light on my Pro Shield ir purifier is staying on
do you hear arcing or snapping sounds when it's powered on? if so check to see where it's coming from, I posted a fix for this in some other posts. check the wires that run along the front of the cell plates, broken loose or sagging wires can cause this
Oreck Air 12GU Instruction Manual
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
My oreck air purifier xl won't turn on
With the Air 8 Models there is a number of issues from the motor to the power supply to the circuit boards. With these old units it is hard to find parts for them. as oreck no longer manufactures them. but if the parts were availible i would estimate around 100 to fix your power issue
4helpful
2answers
How to open and clean oreck xl air purifier
You can download teh manual at
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
1helpful
Hi, i own a oreck XL professional air purifier
You can download the manual at
2helpful
3answers
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
1helpful
2answers
Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Top Oreck Air Purifiers Experts
Marvin
Marvin
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
