Televison & Video Logo
P
Perry Gullett Posted on Aug 30, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for RCA C8540 output transistors. Where can I purchase this item.
goneforever.
Level 3:
Top Expert:
  • RCA Master 14,531 Answers
  • Posted on Aug 30, 2022
goneforever.
RCA Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263834
Points
66315
Redux 1
too long other post )(deleted)
I can not help you lacking
maker and model of this RIG<<<<
a RIG can be anything on earth electronics, or gear as some say.
TV, old stereos gear, radio's endless.
really 1 million things not told.
but that C prefix smacks of secret contracted parts, google can't find it but I will not search all day.
RCA does not make then now.
no gear told
the transistor has date code there, not told that.
nor photos of it.
kinda hopeless sorry
1helpful
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
2answers
Finding a JVC camcorder A/V output cable
Fixya does not sell spares or accessories. Were these items not included in the package when you purchased the camcorder ? They should be available either from JVC Spares themselves, or on Ebay
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
1helpful
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
I have a 42 inch RCA flatscreen that the picture will not come on I have unplugged TV and cable and no change.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
2answers
Tv comes on but wont show or play sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
2helpful
3answers
Tv sparked and made noise and shut off rca model f32648
Looks like the projection is fried. I'm afraid you would have to exchange for new one if you can or purchase new Tube.
Switch mode power supply not switching and buzzing when powered up.
Common failure " buzzing " cause = bad flyback transformer
& horiz output transistor = replace both at same time.......
part # 's 257807 & 237470 RCA only No sub's.........T.
No power and squealing!
There is going to be a wire that is connected to the back of the tube. The item that wire comes from (Flyback Transformer) needs to be replaced. Also, the HOT (Horizontal Output Transistor) is likely bad as well. It'll be a 3 pin unit connected to a heat sync around the Flyback.
2answers
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
