The door goes up smoothly from the open position till about 2 inches from closing. Nothing appears to be in the way. Any ideas of how to fix this or service center etc?
It's possible that the door hinges are misaligned or there may be something blocking the door from fully closing. Here are a few things you can try to fix the problem: 1. Check the hinges to make sure they are not bent or damaged in any way. If the hinges are damaged, you may need to replace them. 2. Check the door seal and gasket to make sure they are clean and in good condition. If the seal or gasket is damaged, it may be preventing the door from closing properly. 3. Make sure there is nothing blocking the door from closing, such as a utensil or food item that may have fallen behind the door. 4. If the door still will not close after trying these steps, it is possible that the door latch or catch may be damaged or not functioning properly. In this case, you may need to contact a service center or the manufacturer for further assistance.
