Freezers Logo
Question about Frigidaire Freezers
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
Model number: GLFH21F8HWC upright one door
Posted by Laura J Marco on
kishnakant chaturvedi
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 307 Answers
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
Posted on Feb 14, 2023
Lost manual for my Fridgeidare upright freezer 20.5 with the controls on outside. what does 0F mean. and if I need to set it ,we just moved how do I set it?
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
1helpful
3answers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
1helpful
Need a manual for 253-9284215 Kenmore Upright Freezer
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Oct 06, 2010 • Freezers
2helpful
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Top Frigidaire Freezers Experts
Marvin
Marvin
nu267
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
