Baby Gear Logo
Question about Baby Gear
2 end rails won't Fit for the bassinet. Eddie bauer3 in 1
It says all six bars must be placed, the 4 in the middle fit. It's the 2 end ones, they seem to be bigger than the dimensions of the inside. How do I go about this
  • Brett Duxbury
    Brett Duxbury Aug 28, 2022
    Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    is it the delta children capri model ?
    the mattress base is adjustable depending on the age and size of your new born !
    The mattress base utilises angled brackets according to this video belowhttps://youtu.be/OK5HDu4cuQs
    The video may not be the same model but it shows how to tackle assembly and the use of brackets on the mattress base
Will a Cameleon Bassinet fit on a Gecko ?
Yes it will but it's a little bit longer then a Geckp so if you have any Gecko rain covers etc they won't fit.
Hi I have a Husqvarna 136 chainsaw the fuel line seems to have seperated/broken off inside the fuel tank. I can not see any place to reconnect it anybody have any ideas
The fuel hose is all one piece from the tank up to the carb, it is just an interference fit in the tank, you will need to replace the complete pipe, the best way to do this is to **** the new pipe up the middle, about 30/40mm, take away one side of the pipe, it will now fit through the hole in the tank from the top, use a pair of long nose pliers through the fuel filler hole to grab the pipe and pull it on in, trim the end and re fit the fuel filter.
I have a delta lov crib model# 4925-2 and i have set it up but i cant seem to get the bottom board to fit so it can support the mattress am i missing something? p.s its already been used and should i be...
It sounds like you have the mattress support rails in upside down. The rails (2) have 2 nubs on each end that attach them to the left and right side of the crib. They look like what you would see on an adults bed that run the length from the head to the footboard. If installed upside down they dont work. There should be 2 swivel tabs on each rail. These face up. The mattress support fits into the very top of the rails and the swivels turn to just sit over the top of the support board and keep it in place. You can go to Delta's site and check for the recall. It is a FREE easy fix. Just plug in your model number and sometimes date of manufacture. They will send you the kit and you are now safe and secure. Here is a link to Delta to check. And as far as worried, it is your child's safety, check it.
Delta Recall Checker
Assembly?
This is a tricky little bassinet to connect to the head and foot board. You should have 2
bolts that are double ended (one threaded one is like a nut with female threads).
These go thru the holes on the headboard and I think the inside (bassinet side) have little guides
or bushings that the bolts ride on. The bottom parts use barrel nuts and long (4-5") bolts. Carefull not
to overtighten these as they will break the wood. There is a small rod that is underneath that locks the bassinet in place keeping it from rocking. Again, they just changed this design and my description may not be exact to yours. I cant seem to find an online source for instructions and Eddie Bauer just went thru
a bankruptcy so who knows. Good luck
2helpful
Where can i find the bedding for the eddie bauer bassinet? i only have the bassinet not the bedding.
Most baby stores (Babies R Us, BuyBuy Baby, Toys R Us, etc) carry bassinet sheets. They have elastic edges so they fit most sizes. I found that for my granddaughters abssinet, there were few color choices so I used pillowcases and tucked the excess under the mattress. Other than that, if you want something made specifically for your brand, generally you'll need to contact the manufacturer or make it yourself.
3helpful
Need Ellis Cherry Crib Conversion Rails (or substitution) in US
Yes all i have a solution for the simplictity problem.
There is a company in Canada that has the conversion rails and other parts you are asking about. They do deliver to the US. There name is The Kiddies Store. The Ellis collection is called the Sydney.
Phone number is 1-800-755-4857
web site is http://www.tjskids.com/simplicity-sydney-4in1-convertible-crib-cherry-p-4226.html.
2helpful
2answers
Finding full sz bed rails 4 my Simplicity Ellis Convertible Crib
The simplicity ellis 4 in one crib plus the drop side were recalled. This is why you can't find the rails. Check the babiesrus.com for your model number to get a refund!
27helpful
8answers
i think i have a solution to your problem. I too have been looking for simplicity bed rails but in honey to convert to a full. I found sears.ca and they carry the rails in every color but there version of the ellis crib is called the sydney 4 in 1. It is the same exact crib so I am purchasing the rails myself. If they do not end up fitting then just send them back. Sometimes canada have the same things as us but they are named different I know I live 15 min away from the canadian border. Hope this helps.
2answers
How do the side rails of a eddie bauer play yard stay up?
I have this the Eddie Bauer Pack & Play too. The directions says it doesn't matter which sides you pull up first but it does... you have to first pull up the 2 short sides, then you can pull up the long sides and push the button on the bottom to get the whole thing secure.
Hope this helps!
Jaime
Nov 17, 2008 • Baby Gear
Top Baby Gear Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you a Baby Gear Expert? Answer questions, earn points and help others
