Cameras Logo
Question about Cameras
Swintech sw20 prints time and date but no amounts
Posted by ron davis on
2answers
1helpful
2answers
Need some1 2 explaint to me how I get the d&t printed on the photo for a canon powershot 1S camera please
you can Print the date and time to the picture when you take the print of it. It does not embed the date and time data into the image itself.
From the manual please read this
" Setting the date and time settings does not cause the date/time stamp to appear on images"
To print with date
This option will be available only for printing on card size paper
In the print order screen, select [Style] and press the SET button
You will get 3 options to set
1) Image
a) Standard b) multiple
2) Borders
a) Borderless b) Bordered
3) Date
a) On ( Adds the date to the print )
b) Off ( Prints without the date )
Select Date option as On and the date will be printed on the picture.
still you are having any doubts, please refer to user manual and Direct Print User Guide
which i am giving as links here.
user manual
Direct print user guide
Hope this helps you
Thank you
Date and time in prints
This function only works in "postcard" resolution. Press function button, and select postcard (1600 pixel width) resolution.
3helpful
Cant get date to print on phots
The photos taken by EOS cameras don't have the date & time overlay. To print your photos with date/time stamp, use Zoombrowser EX software that came with your camera. When you select photos for print, you'll get the option of printing the date/time (and even the choice of font's colour) on the photos.
1helpful
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Print fax journal from previous date on Brother MFC-3820CN
although it may have a time retreival function it will not store 2mo of faxes !! most likely only a few days depending on the amount of fax you receive
2helpful
2answers
Ink cartridge error
Check the date on your ink cartridge.  I bet it has expired.  If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today's date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Time & Date Stamp
The date and time (and a lot more) are stored with every image. Any photo printing program should have an option for printing the date and time on the picture (or in the margin or even on the back if the printer is two-sided).
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
