Ive got a 48 FHD Veon that I want to use as a secondary monitor for my laptop. Ive connected the laptop via the VGA port on the TV. When I power the TV on I dont have a remote, Im using the on TV controls it is recognised on the laptop as an available monitor. When I select EITHER the on-set Source or Menu buttons a grey box appears on-screen momentarily then disappears. The TV then goes into standby mode. If I turn the TV on and wait I get a blank screen and the TV goes into standby mode. I have disconnected the TV from the power supply for 24 hours and tried it again, same result I suppose to clarify my problem I cant select any options in the TVs Source menu. All it displays is a grey rectangle with a grey square in it. Im assuming the grey rectangle should display the Source options, the square defines the source that is selected. The problem is the rectangle doesnt display the options and it cycles into standby mode before I can do anything even if I could see the options. Thx in advance for any help given
Kimkomando.com.Shes adigital xpert..send her an email of ur issue.. Visit her website. She figures out anything digital. Also try to find a similar problm on utube or pinterest
Testimonial: "Thanks Arnie, not sure what you mean? I suppose to clarify my problem I cant select any options in the TVs Source menu. All it displays is a grey rectangle with a grey square in it. Im assuming the grey rectangle should display the Source options, the square defines the source that is selected. The problem is the rectangle doesnt display the options and it cycles into standby mode before I can do anything even if I could see the options... thx for taking the time to answer"
