Garden Logo
Question about Garden
What can i use to flush milky oil out of a riding lawn mower?
Posted by Joe Russell on
ADMIN Andrew
    Top Expert:
  • Garden Master
  • 53,121 Answers
Use flushing Oil. It has additives that clean, while still lubricating.
An engine flush is an aftermarket chemical additive designed to clean accumulated deposits, sludge and other gunk from your engine. You pour it into your engine's oil-filler port and idle the engine for about 10-15 minutes.
Is an Engine Flush Good or Bad? - AMSOIL Blog
Posted on Aug 25, 2022
1helpful
3answers
What cause oil to look milky in a craftsman riding lawn mower?
Hi Joe
They are both telling you the truth, water or even condensation makes the oil milky, Chef Andrew says, "just like making mayonnaise". :>D Run it to running temperature, drain the oil and replace with new. Run the engine once a month in the off season.
What is wrong when oil mix with gas and the riding lawn mower will not start?
Riding mowers are usually straight gas, not mixed. If you accidentally put mixed gas in it the carb, plugs, and engine may be gummmed up. Clean, flush, start with fresh gas, and you should be OK
Mar 08, 2015 • Garden
Will water in hydrostatic oil cause drive not to work
you will need to flush it out water will not seal like oil
May 22, 2012 • Garden
What causes Milky Oil in Lawn Tractor
water or coolant was it out in the rain?change the oil a couple times run it in between with out a load just idle it till warmed up a liquid cooled engine could have a bad gasket or crack
May 17, 2012 • Garden
I have a Husqvarna 42"
You should have the Oil & filter changed per this manual:
http://www.managemylife.com/mmh/owner_manuals/10223/CRAFTSMAN-Lawn-Tractor-L0304249?
To make sure you have the correct manual go to this link and enter your model number:
I tried this model number and it did not work: 960.50002 I think you are close though.
Make sure that it is warm if you can before changing oil. One Procedure calls for removing the transaxle to change oil... It takes 80 oz of 20-50W oil. It is important to FLUSH the transaxle if you are experiencing problems. There is a product caled engine Flush that you can purchase to flush the transaxle.
Mose transaxles that experience motion problems are caused by contaminated oil. Flush.. flush... flush.., then wait for it to drain out... and then finally re-service with 20-50W oil.
Change the Filter too.. if your unit has one. All of them have the internal metal mesh screen which is why it is so important to flush out the debris.
Thanks for choosing FixYa,
Kelly
My craftsman lawn tractor seemed to overheat and struggle with hesitation. I replaced the spark plugs, cleaned the filter and added oil, however, it still seeems a little sluggish with hesitation. Do you...
Check the oil, if it is a milky color then it has water in it and will cause it to over heat. Also smell it for gas that will also cause it to over heat. Has any other work been done recently?
7helpful
2answers
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
2helpful
How much oil should my snapper rear engine 14 hp
The way i would do it. get 2 qts drain and flush oil out of engine. put the drain plug back in. remove the fill plug and fill with oil. i fill mine to the first thread under the fill and ckeck plug hole. keep the rest for adding if required.
Aug 30, 2009 • Garden
2helpful
Change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Aug 27, 2009 • Garden
3helpful
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Open Questions:
Top Garden Experts
john h
Marvin
Marvin
wadingriver
wadingriver
