Maytag 9000 series washing machine. No power after turning on with front panel removed.
MHWE950W Front access panel was removed to clean the drain filter. Turned machine on without panel in place. Started and quickly power went out. I see that there is an interlock switch that would have been depressed if the panel was in place. I have tried the power and start button reset method. My thought is that it would be a fuse but have not located it yet.
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
the drain pump is plugged with foreign materials,you can access the sloped front "MAH" series from the front by removind 4 screws around the door perimeter and removing front panel by swinging outward toward you,others by removing rear access panel on the back side of the machine
"E20" is indicates a drain problem. - Set towels under the hoses in the rear of the washer and disconnect the drain hose. Clean the drain hose screen and look for debris where the hose connects to the washer. Clean as necessary. - Remove the front access panel from the washing machine and locate the drain pump. Remove the screw clamp and clean out any debris that may be causing an obstruction. - Clean the sump hose that is connected to the trap cup and reassemble. Close the front access panel. - Restore power and press "Drain/Spin" to remove any remaining water from the tub.
Unplug the dryer or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place
a container or a piece of towel underneath the filter to catch
spillage. You may need to drain the water from the machine by putting
the end of the drain hose over a container on the floor. Position the
container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Maytag machine is made by Whirlpool and therefore troubleshooting are basically the same. Click on link below for more detailed drain problem troubleshooting.
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
F02 is fault code for DRAIN, the pump may be blocked or the drain hose blocked or kinked. Most washers have an access plug behind the lower front panel of the machine which you can open and check for blockage of the pump.
The
drain filter is located in the pump behind front bottom panel. Disconnect power and remove
remove the filter by turning the knob counterclockwise. Clean the filter
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
