Radio Communications Logo
Question about Galaxy Radio Communications
On my Galaxy Saturn, I'm getting a carrier on SSB.
Several people mentioned try adjusting the carrier balance, and I cannot find out what VR to adjust or the specific sequence if multiple need adjusting. Are you able to provide any help or steer me in the right direction? And when I turn my in line amp on, the carrier is amplified to about 700-800 on SSB, which is about 85% of the total output power if the Texas Star DX1200.
Posted by Robert Matthews on
How do you open the rf power and open the modulation on Galaxy 959.?
Modulation is
VR16 FOR AM and VR 13 for SSB
RF Power is VR 14 for high and VR 18 for Low power on AM
VR 17 for SSB power.
How do i calibrate the meters on my galaxy saturn base radio?
First of all this radio is not a cb radio although you can get the cb frequencies on it. Secondly if you don't know then maybe you adjust it . Thirdly, you need to be certified to do do what you intend on doing to that radio or have a tech present while you do the work. You need a service manual that tells you which variables to adjust and how much to adjust them .
How to adjust rx on galaxy saturn and signal meter
VR8,VR1,VR2, VR3 AND VR 4 THESE ARE THE ADJUSTMENT POINTS FOR THE S-METER FOR AM AND SSB WITH A LITTLE CW INCLUDED.
How to trun the power up on my galaxy dx 55v
AM CARRIER POWER HIGH: VR-13 pot. for RF power adjust
AM CARRIER POWER LOW: VR-16 rf power adjust
I have a galaxy 88 and when u try to use it on ssb the radio will only do half power even with ssb power all the way up!
there is a ssb regulator bad or the power is turned down
this how to adjust ssb power output SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) atMIC jack adjust VR12 Key TX; adjust for 25 watts PEP.
Galaxy 979 SSB Modulation Problem Voice Cuts Out.
It sounds like you had a cold solder joint. Leaving it in the sun probably temporarily corrected it. I would take it to a tech to have all the solder joints corrected, unless you are handy with a soldering iron. The problem will most likely come back.
All you have to do is pull the top cover off, which will show the bottom, or trace side of the board. Using a soldering iron, make sure any solder joint that doesn't fully look soldered and make sure the solder is fully covering the joint. If need you may have to add solder.
As for the frequency counter going nutty when you modulate, Don't worry about it. There is nothing wrong. Because when you modulate you are modulating the carrier signal you are changing the signal so the counter will interpret that as a different freq because it cannot differentiate. Freq counters are for use with carrier only. As long as the carrier shows correct, it is right.
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
NEED TO KNOW HOW TO FIX A RAIDO UNIDEN GRANT RAIDO NEED TO DETUN MY RAQDIO
Probably VR 10 on that radio. You are not really de-tuning the radio, just reducing the carrier power on AM. If you're driving something else, You may also want to adjust VR 11 for a reduction on SSB
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
1helpful
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Top Galaxy Radio Communications Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Galaxy Radio Communication Expert? Answer questions, earn points and help others
