Radio Communications Logo
Question about Radio Communications
Rino 650 ppt button not working
The ppt button on my rino 650 is not working
Posted by peter on
How to solve the shorting battery problem when I use PPT button?
What make and model of camera are you having this problem with ?
Aug 21, 2016 • Cameras
Where is the plugin on the rino 650 garmin
You need to use the AC adapter or specific vehicle charging cable to charge the rino series. They plug into a different port on the unit.
Jul 21, 2014 • Garmin GPS
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
Keyboard locked out unlock keyboard
Google the instructions for the Rino model you own. On mine, once you turn it on, you press and hold the power button and it unlocks.
Frozen touch screen
Contact Garmin via their website. Their technical support (in or out of warranty) is outstanding.
How do I reset the trip computer
Go to Setup>Reset>Reset Trip Data, Timers, etc.
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
4helpful
Can i reboot my rino 530 hcx?
Yes - press the Page (lowest button on the left side), Enter (push in the center joy stick button) and Power (top) buttons at the same time. Then use the joy stick to select Yes indicating that you want to reset the unit.
Garmin rino 530HCx freezes up
pull battery off to reset or hard boot cpu! Its a computer.
Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Top Radio Communications Experts
Marvin
Marvin
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
