Question about Yamaha Audio Players & Recorders
My Yamaha reciever stuck in headphone mode 5960
Was playing on speaker just stoped playing looked at display showing headphone on screen ,wasn't there before
Posted by Dan Hruska on
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
How do i connect headphones to htr-5960
Does it have a headphone jack on the front of the (Reciever)
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Yamaha 5960
Does your reciever use a remote control?
If so, you should be aware that on many recievers and surround amplifiers some of the functions may only be accessible via the remote control (the best way to learn about it is to consult the user manual).
I have a Pioneer VSA-730 surround amplifier and the only way i can change the mix levels for surround/sub/center speakers is by a remote control. My friend had the same problem and, after reading the manual, he discovered that he actually needs to use the remote control to access all functions of the amplifier.
Good luck and best regards
3rq8 (Triarcuate)
No sounds from rear speakers..... Yamaha HTR-5650
Select different modes on the remote or front panel and make sure all speaker that you have hooked up are showing on display. Are the Lt & Rt channels at least playing audio? If you want, i can step you thur some steps to try in live chat if you want today. Let me know as i have experience in this area! Sincerely Guru Jay
2helpful
2answers
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Top Yamaha Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
