Televison & Video Logo
Question about Pioneer Televison & Video
Pioneer plasma TV model PDP-4271HD. When I turn the power on it starts to come on and then shuts down the blue Power indicator light flashes.
Posted by Birchem Nick on
Larry
  • Pioneer Master
  • 4,587 Answers
Unless your a skilled electronic tech and have the test gear to trouble shoot the set don't waist your money trying to fix it. Plasma sets are about 10x more complex than a LCD set
Posted on Aug 19, 2022
TV will not turn on. Red light comes on and flashes off and on.
Check the number of flashes (will be a sequence of just regular flashes... or a sequence of short and long flashes) ... once you have this ... call your service agent and ask for a quote ... first google the flash sequence and se what the code means.... could be as simple as a simple board change.
1helpful
Pioneer pdp-4271 plasma will not turn on, tried unplugging it and letting it set and plugged back in not turning on, i have checked the outlet for power and it is good also checked end of plug that...
The tv have a power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
4helpful
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
1helpful
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
4helpful
2answers
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Help
Yes, it has built-in stereo speakers with TruBass enhancement:
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/PlasmaTVs+Monitors/Other/PDP-4271HD
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
