Computers & Internet Logo
Question about CyberPower Computers & Internet
CyberPower 1500VAR LCD light flashing. I replaced the batteries, but will still go back to flashing after about 5 seconds.
Posted by Gary Hobish on
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
CyberPower CPS825AVR trips after 5 seconds
Needs a new batter most likely. The same thing happened to my CPS825AVR that I use in my home office. Emails to CyberPower went unanswered so I had to solve it on my own. It uses a lead acid battery much like those used in emergency lighting, and not unlike a battery in your car. It will initially fail to keep your electronics on after a power failure, just shutting off and beeping like mad. Then it will fail to stay on entirely. Try holding down the red reset button for a period of time. It may reset, but chances are it will not work after you unplug it from the wall to simulate a power outage, and will need to be reset again.
For me the first failure occurred when the unit was left in storage. Like most batteries a lead acid battery if left uncharged will deteriorate and be unable to hold a charge. The second battery purchased online just failed after barely more than one year. It was a battery made by Werker, which is a very common replacement battery for emergency lighting also. At this point I am not going to spend any more money in this unit. It is unclear to me as to whether it is a lousy battery or the unit is unable to maintain a charge in such a way that the battery will survive a long life.
I will buy a UPS made by APC, I am using an APC for my entertainment system now. They are more readily supported and offer more options with regard to replacement batteries. I suggest finding a model to suit your needs and then search to see what support there is for it. I got about 5 years out of the first battery and was able to easily get a replacement online. The APC batteries are also relatively competitive in pricing so there is less need to pursue an aftermarket brand.
2answers
Power light is out. Is the unit dead?
Atypically if this is an older unit what you have is an issue with the battery. It will no longer hold a charge.
You will nee d to go to the vendor site and look for a replacement battery.
In some cases it may be less headache and cost just to buy a new one.
Cyberpower 575SL stored unplugged x 5 wks-won't power up
check the battery it could be the battery is dead.. if it is so replace the new batts.. than plug in the power to ups.. n turn on it i suggest doen't turn off the power all the time i might cause the lifespam of the battery to shorting.. normal the ups can be use up to 3 yres time..
9helpful
2answers
Cyberpower 725SL Intelligent Back Up Power: This unit now just flashes on / off. When I press the red button and then back on again - it continues to flash on / off. I have tried plugging it into other...
It would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP9-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at [email protected].
8helpful
8answers
Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Computer dead
CyberPower battery backup units carry a connected equipment guarantee.
Please contact the Claims Department at CyberPower Systems at 877-297-6937.
2answers
CyberPower 325SL backup system
How old is the unit and have you ever replaced the batteries?
CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Top CyberPower Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
