Question about Magnavox Audio Players & Recorders
My magnavox jogproof 45esp dosent work
It makes a faint sound when the play button is pushed and that's it.
Posted by Harry Francis on
1helpful
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Phillips jogproof 45 esp stopped turning on
Unless something has happened to it in the last hour then it would seem the problem has something to do with the batteries or connections or the way you fitted them.
Batteries should be fitted with the greatest care as accidentally putting them in wrong can cause terminal damage to the device - in a second!
It isn't unknown for a new battery to be faulty so I suggest you first test the batteries and if ok next check the terminals in the battery holder appear new and shiny and thoroughly clean any that aren't.
Sky remote does not operate the sound on my philips tv.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
The screen was dark but if you look closer you will be able to see very faint picture, i can make can barely see the menu when i press the buttons.
well take it back and get another one or get a reaprist guy to fix it.maybe ask someone from were you got it and tell them this computer dosent work.are you playing a game for it or doing downloadung with it.
1helpful
My 50 "Magnavox rear projection has a vary faint picture
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
sorry
6helpful
T.v. won't turn on.
need to replace power inverter board if need to contact call 304 885 0225 shon
Phillips projection no picture
It sounds like you hit the AV button. Try hitting it again until you see a picture.
Top Magnavox Audio Players & Recorders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
