Question about The Audio Players & Recorders
My player does not work , I get a faint noise when I press the Play button
Posted by Harry Francis on
All of a sudden our Bose player makes clicking noises when pressing the start button, and music does not play. What should I do?
My guess is the player is getting old and needs servicing. The clicking could be a bad laser or the power supply feed line that powers the laser/optical pickup assembly.
1helpful
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
2answers
I want to play Dvd's from Europe so I want a region code free.
1. Power ON the main unit (some unlocks work with, some with no disc inside)
2. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFER menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, aPREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions - it worked on my PD9012/37 that was region 1
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
6helpful
My volume control is not working properly. It says AVLS. What does that mean?
AVLS stands for Automatic Volume Limiter System - and it basically limits the maximum volume being output which is why your volume control isnt working properly. You will need to go into settings to turn this option off.
Press and hold the back/home button until the HOME menu appears, press the arrows to select Settings then press the Play button to confirm, press the arrows to select Common Settings then press the Play button to confirm, press the arrows to select AVLS(Volume Limit) then press Play button to change it to OFF.
My mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black,...
my mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black, what is wrong
4helpful
2answers
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
13helpful
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
2helpful
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Movie is playing, but will dont display on screen
Try increasing the contrast. If that doesn't work, then make sure your input is on the correct setting. Press the input button and wait for a picture to load (about 5 seconds each) while trying to play a DVD. Also, make sure that the backlight is enabled. If you take it out into the sunlight and you are able to see a faint image of the movie on the screen, then you need to turn your backlight on. Most likely an option in the main menu, but it may also be caused by a broken sensor that senses when the player is closed and turns the backlight off, but also turns it back on when the player is opened.
Seeing picture on monitor of dvd player
I have the 7 inch monitor but my manual says: "If you feel bright unsuitable during playback, press MONITOR button to select bright adjustment and press + or - buttons until moderate bright is available." If that doesn't work you may have stumbled on the reason the company is no longer in business. They sold crappy stuff.
Open Questions:
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
