Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
The water-inlet valve lets water enter the machine. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
