Toys Logo
Question about The Toys
Servos slightly quivering with occasional jolt
Brand new transmitter and receiver T14SG, R7108SB receiver, 7985 digital high torq servos, 4.8v. Hitec Gyro. no pull pull cables or long rods that might cause interference. What i was thinking maybe not enough voltage for the digital servos.
Posted by chris walsh on
Um 400 a hiss in audio
Run the gain control on the mic high enough to get the red limit LED to occasionally flash. Then turn the gain down at the receiver to compensate for the higher level coming from the transmitter. I'm a factory repair technician at Lectrosonics.
Servo not drawing enough current
The high load may have damaged the motor to the point where some of the windings may have melted the insulation.
That will result in less magnetism or torque to spin the motor.
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Plugged in charger and got not light on charger for transmitter. Replaced rechargable batteries with AA's turned on transmitter not lights on transmitter. Rechecked polarity on batteries and they were in...
what charger?
it needs to be designed for that particular transmitter, four cells, reverse polarity to Futaba and Hitec
http://www.rcgroups.com/forums/showthread.php?t=839823
2answers
I BOUGHT TWO HELICOPTER FOR CHRISTMAS FOR MY TWO SONS. THE ESKY LAMA V4 AND THE BIG LAMA. THE BIG LAMA WORKS GREAT AND FLIES WELL, BUT THE ESKY LAMA V4 ACTS STRANGE. WHEN YOU CONNECT THE BATTERY THE SERVOS...
I have exactly the same problem. It used to work fine for a long time but all of a suffen i got this problem. Do not yet know how to solve it.
Carl C
Jan 09, 2011 • Esky Toys
SMT transistors marked UXR and UYR I need further information so that I can source for repair
I had the same probem with my Hitec HS225 servo.brand new one that I opened and played with a little too much = (
I found out that hitecs cheaper servos has identical electronics inside and I managed to transfere one.
//Olle
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
2answers
Can't get new transmitter working on remote control car?
your receiver is old 89-92 and will not work properly with your newer transmitter. you need a R122JE receiver.
I have a Futaba T9CP transmitter sending to a FP-129DP receiver and on to 6 digital servo's 4 hitec and 2 futaba and they all appear to be delayed in there response to the transmitter movement and they...
have you got any expo dialled into the settings, this will delay or rather soften the response to your servos, the glitching you are getting may be due to you be close to the reciever and swamping the sinal hence the glitching, see if it goes when you walk away from the transmitter
Top The Toys Experts
vince
Marvin
Marvin
Are you a The Toy Expert? Answer questions, earn points and help others
