Question about The Audio Players & Recorders
I am just setting my DX2000 USB mixer up. Everything is distorted even with gain at min.
I have plugged in my pc to it and it started off being very distorted. Fine. I turned the speaker level down on the pc. I plugged a CD player into it and it is distorted too. I can't change the level of that going into it, so how do I stop this distortion. Gain is at min. It is not the speaker because it sounds the same on headphones.
Posted by Neil Ogden on
I hear a white noise when I connect microphone with mixer (Behringer DX2000)
You posted this in questions about the Shure PG42 mic. That mic comes in two versions. There's the USB version which connects direct to a PC. Then there's the standard version which is used with a mixer. I presume you have the standard version as the Behringer doesn't have inputs for USB mics.
The standard version is a condenser mic. It needs power. The power is supplied by the mixer. It is known as phantom power because it travels up the mic cable from the mixer to the mic.
  • Make sure your mixer has phantom power switched on.
  • Use the correct mic cable: Either a 3 pin XLR to 3 pin XLR, or a 3 pin XLR to 3-pole jack (TRS). The leadis a balanced mic cable
  • Check the setting on the mic for attenuation. 0dB is no reduction in signal level. 20dB is a large reduction
  • Look at the Behringer's settings. Make sure you know what each control does and how it affects the sound. Pay particular attention to the effects send and return (FX SND RTN)
Most times there's an issue with no sound from a mic, it's usually down to a poor quality or broken cable; or no power; or the settings on the mixer.
Channel 4 is 10 times louder than other channels why? all gains ect set the same nearly blew my speakers
Try swapping the input with another channel and see if the problem moves. Be sure to set the levels down or you may get your speakers this time. If the problem moves the source is the bad guy. If not check the gain setting, not the slider. The gain is normally the top know on the channel.
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
I just got a mackie 1640i mixer yesterday. I followed all of the correct steps in setting it up towork with logic pro. However, when listening to any audio coming through the mixer, there is this awful...
Likely you haven't got the levels set properly. Start with the trim controls (head end gain) Make sure you are not clipping there. Also verify you aren't overdriving your amps. Remember that the outs are line level, not mic level so the gain oof following equipment needs to be set for line level.
ALWAYS USE balanced audio line from this unit... either XLR or TRS type cables. ALWAYS power ALL interconnected equipment from teh same receptacle or source to avoid ground bounce damage to circuitry. You don't say what you are using to record with. Make sure it has balanced inputs. For instance, connecting cables from this to the audio input jack of a PC which is unbalanced would be a disaster in audio quality. There would be a problem of levels and the unbalanced thing... You haven't given us enough information of your hardware configuration to analyze the problem more than what I have said here.
Im having distortion problems on my microphones, how do I activate the compressor on my mixer?
You can't activate something you don't have. The XENYX do not have compressors built in.
If you are getting mic distortion you are not properly setting up the mics.
You one at a time press the PFL down and have someone yell at the mic the loudest they will ever be. You adjust the trim control for that mic to be below the clip on the LED display. The you turn that PFL off and go to the next mic.
From that point all mic adjustments are from the slider. If you can't get enough gain, then back off ALL the other non-mic inputs and crank up the main slider and/or the power amp gains.
You have to learn to balance all the gains.
There are instruction videos on YouTube under "Soundboard".
I have an intigrated motherboard, I've changed speakers and installed a new sound card why am I still getting a distorted sound...even from start-up
the mother board may be the problem it has happened to me before i checked all the wiring and all the slots and made sure everything was plugged in correctly, i also took the clock battery out this resets the mother board and it can solve small problems like this one unplug it from the wall when you do this to make sure it resets everything then put it back together after about 5 min and it should work properly again
Distorted audio into AG_DVC7 Digital camera from Mixer Aux send
set the camera audio switch to line, not mic feed. This switch is on the camera. Adjust the audio gain to -60db in the menu settings.
Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Help please
1. plug usb into PC
2. plug usb into camera
3. turn camera on
Windows should report that it is detecting a device. If it doesn't then it may be because the camera's hard drive IS the device it would supposed to be detecting, nes pas?
Open Questions:
Top The Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
