Ovens Logo
Question about GE Ovens
F73 code GE profile double oven
GE monogram double oven F73 code well open is heating up it'll work for a day or two and then it goes into F73 code I shut the circuit breaker and then turn it on and it's OK for another day or two what is the problem
Posted by anthony dinota on
GE monogram wall oven displaying Loc rEF
Model: PT956SR2SS GE double wall oven has "LOC rEF" code Press 6 & 8 at the same time to resolve this issue
Ovens won't heat
Have you set the clock alot of ovens need the clock set so the oven will work, this is a safety thing so if you set the oven to turn off after 1 hour or at a certain time of day and say the power went out or the gas was turned off and came back on then the oven won't just start up on its own
1helpful
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 • GE Ovens
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Top GE Ovens Experts
Marvin
Marvin
David Shaub
Are you a GE Oven Expert? Answer questions, earn points and help others
