Garden Logo
Question about Craftsman Garden
What cause oil to look milky in a craftsman riding lawn mower?
Posted by Joe Russell on
ADMIN Andrew
    Top Expert:
  • Craftsman Master
  • 53,546 Answers
Hi Joe
They are both telling you the truth, water or even condensation makes the oil milky, Chef Andrew says, "just like making mayonnaise". :>D Run it to running temperature, drain the oil and replace with new. Run the engine once a month in the off season.
Posted on Aug 19, 2022
J Keef
    Habit-Forming:
    New Friend:
  • 11 Answers
Water has gotten in the oil some how is cap on tight or maybe water got in there when you used a water hose to clean it or left it out in the rain does your cap have 3 or 4 tiny vent holes water will go through these tiny holes at any rate I would drain the oil and put in clean oil
Posted on Aug 14, 2022
  • Joe Russell Aug 15, 2022
    the cap is tight i didn't use no water hose the cap have no vent holes the mower engine up sometime.
  • J Keef Oct 02, 2022
    Sorry it took me so long to get back to you, but what happened to me a couple times was, I got gas at the gas station in my gas can once forgot and left it outside and I guess it rained and I didn't know water got in the gas and I tried using it in my mower and trimmer had a real hard time getting them to run I checked the gas in can and that is when I knew water got in there. Another time I got bad gas that had water in it from the gas station. So u never know how sometimes it just happens.
Larry Ng
    Top Expert:
  • Craftsman Master
  • 11,398 Answers
Water in the oil does that!
no mower told,model. number
100s made, none the same.
just bought it like that.?
or doing service steps found it.?
do no run any engine on earth water in the oil sump.
period.
someone pressure washed the beast?
left oil cap off all winter in the rain/
or?
  • Joe Russell Aug 14, 2022
    I don't see how water get into the oil the oil cap is on all the time.
    Do u take a water hose sometime to clean the mower, or could moisture had gotten into the oil bottle that you used to pour oil in the mower. I don't know how I did it but I got water in my oil after I hosed it down I guess I sprayed water in the oil somehow it wasn't much but then again any moisture in the oil is bad had to dump it out and put new oil in it
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 • Garden
What causes Milky Oil in Lawn Tractor
water or coolant was it out in the rain?change the oil a couple times run it in between with out a load just idle it till warmed up a liquid cooled engine could have a bad gasket or crack
May 17, 2012 • Garden
1helpful
Specifications, for Craftsman Riding Mower, Model 247.289010. Quanity for oil.
Without an oil filter you will need approx. 48 oz. With an oil filter about 18 oz more. Hope this helps. You should have dipstick to register when it is full.
My craftsman lawn tractor seemed to overheat and struggle with hesitation. I replaced the spark plugs, cleaned the filter and added oil, however, it still seeems a little sluggish with hesitation. Do you...
Check the oil, if it is a milky color then it has water in it and will cause it to over heat. Also smell it for gas that will also cause it to over heat. Has any other work been done recently?
1helpful
2helpful
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Top Craftsman Garden Experts
Dwain Pippen
john h
Jay Finke
Jay Finke
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
