Televison & Video Logo
Question about Toshiba Televison & Video
Internet on my old Toshiba RV75
It says it's connected via wire setup but no idea how to actually view it. There's nothing I can see on the remote and the manual does say anthing that makes sense. Never had any need to do this in all the time I've had it.
ADMIN Eric
    Top Expert:
  • Toshiba Master
  • 37,733 Answers
Probably you need a digibox between your internet connection and the old TV.
Posted on Aug 14, 2022
1helpful
Is it possible to connect my toshiba RV75 to the internet
Yes it does. Please read page 33 in the user manual and follow the instructions. If you don't have a copy, you can download it
>> HERE <<
(Click on link above to download the user manual from the UK Toshiba website.)
I can't access the advanced settings on my Curtis-Mathis TV
is it possible to connect my toshiba regza rv75 tv to the internet
Remote to an OLD Toshiba TV (model 37a33) is lost and I'd like to replace it OR possibly use cell phone for IR signal. Reason is I want to change video source but TV does not have button to allow it. Any...
If you wish to buy its original remote control, contact the authorized service center for Toshiba. If you wish to buy a universal remote control, check the code list to the remote control you do buy, have set-up codes to Toshiba TV. Setup codes to Toshiba are
1088 1077 1061
1070 1203 1423
1093 1466 1048
1213 1047 1141
1046 1231 1144
1276 1054
If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your Toshiba TV, and buy that brand remote control according to availability. Brand name to a universal remote isn't a matter, but it should have setup codes to Toshiba. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
DI-524 router printer sharing
All you have to do is that you will have to setup your Hp to share or to be seen by other machine on the network by going to the network properties then setting the network, file and folder on your hp to be seen and shared by other machine.
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Ps3 60gb setup problem.
I have the same problem, I was told to buy a HDMI CABLE I did
but it still wont work
2answers
Worsening Wireless, and no Wired
Ok sounds as if ya got a right "Pickle" lol There are a few things we can try.. First I want you to reinstall your network adapter drivers, make sure they are the most-up-to-date. Then I want you to completely re-setup you internet connection from the beginning again, using the internet connection manager and connection wizard with setup a home network... I want you to Check your Ethernet Cable connections.. better still get a NEW Ethernet Cable.. Below is a link to help www.microsoft.com/windowsxp/using/ networking/setup/wired.mspx
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
